Guys
I could use a little help with my LPG system.
The problem I have is it keeps freezing up.Now at the bottom of the part that freezes there is a water jacket that takes hot water from the top of the motor (Its T'ed into the existing system) runs it round the vaporiser and then returns it back into the motor to be added to the rest of the water and ejected all as per normal.
Right for some time it seems to be air locking thus allowing now water to run through sad LPG parts and therefore they freeze up. Boat stops….much swearing fix boat and we are all good for the rest of the day.Any ideas how I can stop the air lock or add some sort of auto bleed to it.
It’s a PCM 351 Ford motor with a professional install of the LPG kit.
Cheers
FLY
Cheers
FLY
