Tachometer / Hour Meter Stopped Working
  • BP22
    • Jan 2007
    • 248
    • Covina, CA
    • 2006 Super Air Nautique 210
    My tachometer and hour meter stopped working this morning. Worked fine Friday and Saturday and even on the first few starts & stops this morning but then it stopped working completely.
    I have a 2006 SAN Signature Edition with the Faria analog gauges with the analog tach and digital hour meter.
    Any suggestions???
    Thanks!
    Brandon
    2006 SAN 210
    RE: Tachometer / Hour Meter Stopped Working
    Look under the dash for a wire that is no longer connected to the tach. I think it might be gray.
    • BP22
      • Jan 2007
      • 248
      • Covina, CA
      Re: RE: Tachometer / Hour Meter Stopped Working
      Thanks Daniel, I take a look.
      Brandon
      2006 SAN 210
      • 2gofaster
        • 671
        RE: Re: RE: Tachometer / Hour Meter Stopped Working
        The tach in the later model SE's is known for issues. It usually starts out with the hour meter failing randomly followed by complete failure of the tack at some point. If you don't have a loose wire, then call your dealer for a replacement gauge.
        Shane Hill
        2014 Team 200OB
        67 '13 Prophecy
        • BP22
          • Jan 2007
          • 248
          • Covina, CA
          Re: RE: Re: RE: Tachometer / Hour Meter Stopped Working
          Thanks Shane. It was weird because it all happened at once. This leads to me think it is a loose wire. Now I just have to pull the dash and dig around.
          Brandon
          2006 SAN 210
          • herd2243
            • Jul 2006
            • 61
            • Scotland
            RE: Re: RE: Re: RE: Tachometer / Hour Meter Stopped Working
            Bad Gauge, I had to replace both of mine, sometimes the digital read out would work, then other days not!!!
            Herd2243
            Now 2005 SV211 TE
            was 1998 Super Sport
            was 1988 Nautique
            • BP22
              • Jan 2007
              • 248
              • Covina, CA
              It was the purple wire with the black stripe that had come off. Easy fix.
              Thanks everyone.
              Brandon
              2006 SAN 210
