So i hadn't run the boat in a few weeks, flushed it once during that time on the trailer at idle for a few minutes.
Yesterday we dropped it in, she started right up. I pushed the neutral switch and gave her a bit of gas, but when i dropped back down to idle rpm's one or more of the cylinders were not firing. I could easily tell by the sound. The engine continued to miss at any rpm level. Turned the engine off, then restarted and still missing.
I brought the boat back to the house, let it sit for maybe 30 minutes, then restarted and all cylinders were firing (at least from what i could tell by the sound). So again I attempt to put in neutral and give some gas, same problem as before and reverted to missing at any rpm.
I have new spark plugs installed, and looked to see if the plug wires had any nicks in them. Did not notice anything. By what I have read on the forum, my next step would be fuel pressure?
Thanks for any insight you guys could give.
