RE: Re: RE: 2002 SAN GT-40 engine missing
Sounds like the TFI module in the distributor. The TFI is the flat thing that bolts to the front that the flat harness plugs into. If you ever have an issue with eratic idle or missing on a TFI equipped Ford EFI, that's usually the cause. You need a special socket to pull it, but you can get that at the parts store.
