Perfect Pass Switch
  • WA-H2O-SKI
    • Jun 2009
    • 77
    • Orondo, WA
    • 2017 Ski Nautique 200 Team - Current Boat
    Perfect Pass Switch
    OK. I am getting more and more serious about some short line skiing. This summer I worked my way up to 32' and 35' Off. I have a 2003 196 LE with perfect pass 6.4. My question is, would the purchase of a switch (inline rope switch) do me any good? And if so, where does that switch wire into the boat? Where do the wires run? Would I be better off getting star gazer? Oh yeah, I run in a river with slight current.
    Thanks,
    Steve
    2003 Ski Nautique 196 LE - Current Boat (Star Gazer w/ ZBox)
    GOODE Flextail 66.5 - Powershell 5 Bindings (LFF)
    PB: 2 Balls @ 39.5' OFF (34.2 MPH Zero Off) Big Dawg Broho Tournament Summer 2015
    1987 Dixie Super Skier 299 - My First Boat
    1987 Barefoot Nautique - Brother's Boat
    1985 Ski Supreme - Dad's Boat
  • 2gofaster
    • 671
    RE: Perfect Pass Switch
    I'm not sure that PP sells the switch any longer. If you can find one, great. Do you ski tournaments? If you do, using the switch with the kx set to - and px set to +15 or 20 will do a decent job of simulating the pull of Zero Off. You might need to upgrade to 6.5ng sw to use the switch, though. The switch just plugs into the side of the master module. Don't forget that you'll need to order new ropes for use with the switch.
    Shane Hill
    2014 Team 200OB
    67 '13 Prophecy
    • AirTool
      • 4049
      • Katy, Texas
      Also, can you use the switch w/o the timer?
      To use the timer, the course needs magnets. If your course has magnets only on one side, you have to either 1) have two timers 2) ski one direction or 3) move the timer back and forth each pass.
      • oldslalomskier
        • Aug 2009
        • 131
        I think Max at skiertoskier.com still has the swicth for $150. AFAIK, magnets not needed.
        • pj
          • Oct 2003
          • 323
          • Rochester, MN
          • 1991 SN 1996 SN
          Pretty sure the switch has no effect on the RPMs unless you are in the course aka timing has been started via magnet or hand timer.
          Once you have tasted flight, you will forever walk the earth with your eyes turned skyward. For it is there you have been and there you will long to return. - Leonardo De Vinci
          • WA-H2O-SKI
            • Jun 2009
            • 77
            • Orondo, WA
            Does upgrading to star gazer eliminate the need for the switch?
            • 2gofaster
              • 671
              Yes, it does. I'm not a fan of stargazer, though. One almost every boat with it, you really have to baby it as you acquire speed. too much throttle and the boat runs away at the gates. Total pain in the butt if you ask me.
              Shane Hill
              2014 Team 200OB
              67 '13 Prophecy
              • G-man
                • Jun 2004
                • 428
                • Allen, Texas
                Re: RE: Perfect Pass Switch
                Im familar with this happening with throttle by cable. Does this still happen with TBW boats and stargazer?
                Current
                2003 SkiNautique 206 LE Yellow - Black - Silver Cloud
                Previous Fleet
                2006 Ski Nautique 196 SE Titanium - Black- Silver Cloud
                2004 Ski Nautique 206 LE Red - Black - Silver Cloud
                1993 Mastercraft Stars & Stripes 190 Red
                • 2gofaster
                  • 671
                  RE: Re: RE: Perfect Pass Switch
                  No, the runaway problem isn't really there on the DBW boats.
                  Shane Hill
                  2014 Team 200OB
                  67 '13 Prophecy
                  • WA-H2O-SKI
                    • Jun 2009
                    • 77
                    • Orondo, WA
                    so star gazer on a throttle cable boat is going to be troublesome?
                    • G-man
                      • Jun 2004
                      • 428
                      • Allen, Texas
                      if you run on a short set up lake you need not to over-throttle past the speed you need or the system surges trying to find the speed you need.
                      Current
                      Previous Fleet
                      • 2gofaster
                        • 671
                        Even on a long setup. Our lake is 2500ft long and if you accelerate up past the rpm where the SG acquires control you might go through the gates at 40mph. Two boats with SG do it and another doesn't. Now that we have two ZO boats the others don't get used much so it's not that big of a deal. But we've gotten pretty good and catching it, feathering the throttle off to deacquire control, and then run it back up so it takes over again. Pain in the butt, if you ask me.
                        Shane Hill
                        2014 Team 200OB
                        67 '13 Prophecy
                        • WA-H2O-SKI
                          • Jun 2009
                          • 77
                          • Orondo, WA
                          Well, I want to take our 2003 196 LE with perfect pass 6.4 to a more current level. Since Zero Off is NOT an option for my boat (since I and not drive by wire, here are my options as I see it:
                          Purchase a switch and just add that to my current set up
                          Purchase the Star Gazer Upgrade (requiring me to buy the multi-line display)
                          Wondering, will the switch work with the single line display and 6.4 or will I have to upgrade to 6.5 and a multi-line display.
                          What is going to get me the closest to Zero Off???
                          • G-man
                            • Jun 2004
                            • 428
                            • Allen, Texas
                            Beleive or not if you call perfect pass and talk to them they can answer your specific questions. They have some of the best phone support
                            Current
                            Previous Fleet
                            • WA-H2O-SKI
                              • Jun 2009
                              • 77
                              • Orondo, WA
                              Agreeded, BUT always nice to have some other input past the company selling the product. Each car salesman seems to have the exact car for my needs and each one is just the best ever....... I like to get the "other" story as well. Anyone have more imput?
