Scratches to Gel Coat
  • camjam
    • Oct 2009
    • 17
    • Ohio
    I purchased a 1999 Air Nautique this summer. The boat is in good condition, but has two areas of scratches on the bottom of the boat where the boat slides up on the bunks. Looks like someone took sandpaper to the area. No deep gouges, just roughed up.
    Any recommendation on fixing the gel coat or is this something better left alone?
    camjam
  • behindpropellers
    • Apr 2008
    • 97
    • Chippewa Lake, Oh.
    RE: Scratches to Gel Coat
    Leave it alone, its normal.
    Tim
    • Madhat78
      • Dec 2005
      • 105
      • NorthEast
      sounds like the previous owner beached the boat which is very similar to taking sandpaper to the hull. You can see if a gel coat specialist can wet sand them out or use a heavy compound. The boat will probably have to be lifted off the trailer though depending on where the marks are.
      • camjam
        • Oct 2009
        • 17
        • Ohio
        I do not believe the boat was beached as the affected area is only were the bottom touches the bunks.
        • Madhat78
          • Dec 2005
          • 105
          • NorthEast
          There could have been grit on the carpet on the bunks or the carpeting is worn... It still should be able to be sanded out or compounded if it's not too deep.
          • behindpropellers
            • Apr 2008
            • 97
            Re: RE: Scratches to Gel Coat
            What color is that boat? I wonder if it was the one that used to be here?
            Every ski boat bottom looks like that after going on and off of the trailer 10 times.
            Save your money for boat gas.
            Tim
            • ClemsonDave
              • Oct 2004
              • 659
              • Glen Allen, VA
              • Ski Nautique 200
              RE: Re: RE: Scratches to Gel Coat
              I agree. However, if you want to get them out, you will need to sand and buff. Start with the highest sandpaper that will get them out. Then sand to 2000 grit. Use soapy water to lubricate. After 2000, buff with rubbing compound and a random orbital buffer (I like Porter Cable). Then buff with scratch remover. That should take care of it.
              Promo Team member
              1999 196
              2010 200 Team 2010 200 Team
              2011 200 Team 2011 200 Team
              2012 200 Team - 2012 200 Team
              2013 200 Team - 2013 200 Team
              2014 200 Team - 2014 200 Team
              2015 200 Team - on the way
              • Hollywood
                • Sep 2003
                • 1930
                • WIIL
                There are compounds that will take out all the way down to 1000 grit scratches, so no need to sand much past that.
                • camjam
                  • Oct 2009
                  • 17
                  • Ohio
                  Tim,
                  Previous owner has a place on Berlin. The boat is tan and green. I would post a picture of the boat, but not sure how. Based on what is being posted, I will probably leave the scratches alone since I trailer the boat every weekend. Though that would change if can find a cheap used boat lift.
                  camjam
                  • behindpropellers
                    • Apr 2008
                    • 97
                    Re: RE: Re: RE: Scratches to Gel Coat
                    Tim,
                    camjam
                    I would buy one of the vertical lifts from http://www.lakesidelift.com/ if you are looking for a lift. We have 4 of them here, and they are great lifts. You can probably get a good winter special on them. You can come over an look at one if you want.
                    Even if you put your boat on a lift I would not buff out the bottom where it rides on the bunks. A good analogy is kinda like the guy who wants a clean oil dipstick.
                    Tim
                    • camjam
                      • Oct 2009
                      • 17
                      • Ohio
                      RE: Re: RE: Re: RE: Scratches to Gel Coat
                      The wife says I have been spending too much money on boat /ski equipment. I keep telling her it will make it easier for her. She's not buying the line and now has me on a short leash. Currently looking for something used.
                      camjam
                      • camjam
                        • Oct 2009
                        • 17
                        • Ohio
                        Tim,
                        Do you know if the guy with the SN for sale on Chippewa? Is he ready to sell his lift separate from the boat?
                        camjam
                        • behindpropellers
                          • Apr 2008
                          • 97
                          Re: RE: Re: RE: Re: RE: Scratches to Gel Coat
                          Tim,
                          camjam
                          Yes, I know Ryan. No, he is not selling it seperate from the boat.
                          That lift might be a bit small for your boat anyway.
                          Used lifts are out there...but often turn out to be just as much $$ as a new one after somebody has not maintained it for its lifetime.
                          Tim
                          • 2004196
                            • Dec 2007
                            • 162
                            • University Place, WA
                            • 2006 196LE
                            camjam
                            I would suggest staying with new as used wives can come with the same biases about spending money on boats! Yellow_Flash_Colorz:
                            2004 196 LE Black/Grey
                            330HP Excalibur Water Churner
                            2002 Grey F150 Harley
                            475+HP Supercharged Tire Burner
