To winterize or not
  • cam05210
    • Nov 2006
    • 74
    • Charlotte, NC
    To winterize or not
    I was talking to a friend about general maintenance and living here in NC where our winters may get to the upper 20's and every blue moon we may get a handfull of nights that are lower, my buddy asked why was it necessary to winterize the boat. Obviously in more extreme temps it exposes the block to freezing, but he thought that simply wrapping the engine in a thick comforter/blanket and being under cover and under covered storage that the temps wouldn't get cold enough to freeze the block or ballast lines. So what's the thought? I have always winterized, but he makes a good point. Discuss...
  • Nautiquehunter
    • Jun 2008
    • 2080
    RE: To winterize or not
    Most of the cracked blocks happen in states with mild winters like yours . It only takes one night in the upper 20s to cause the damage. It only takes 15-20 min to drain the water? I keep mine in antifreeze to prevent rust and gaskets from drying out.
    • WakeSlayer
      • Sep 2005
      • 2069
      • Silver Creek, MN
      • 1968 Mustang
      Winterize no matter what.
      the WakeSlayer
      1968 Correct Craft Mustang
        He does not make a good point. If he gives you other advise like this, I would question your "friendship" with him.
        A space shuttle blew up because the O rings in the solid rocket fuel boosters got too cold. Every so often, Florida loses an Orange crop because of freezing.
        Due to the labor of removing, disassembling, inspection, reassembling, and reinstalling an engine, If done at a shop, it is cheaper to just replace the engine with a new one.
        Remember, Ford no longer makes 351 engine blocks anymore.
        It is also a good idea to run your engine every two weeks, if you do not prepare it for long term storage.
        Spend the time now, or you could possibly not have the use of your boat for a while next spring.
        • jmo
          • Mar 2006
          • 710
          • MA
          A couple thoughts:
          1. Its a $5,000.00+ mistake if your block freezes on the one freak snap of cold weather you get. So, I would winterize it just for peace of mind knowing your boat is fine no matter what.
          2. One side effect of going through the process of winterizing your boat is you end doing an up close and personal examination of of your boats systems and you will catch small issues (loosed clamps fittings, cracked water hose, impeller on its way out, clogged strainer, etc) that could develop into larger problems later and ruin a day on the lake when something does go wrong...
          HTH's,
          jmo
          2018 Ski Nautique 200 TE, H6
          • snowboardcorey
            • Dec 2007
            • 105
            • Minneapolis, MN
            • Past: 1968 Ski Tique
            I would always winterize!!! Call it long term storage if it makes you feel better, but I would highly recommend doing it. I've had to inform more than one boat owner that their "heated" garage lost heat at some point and now they need a new engine, its not a good feeling for me or them.
            Sold my boat to buy a house, the house is much less fun.
            • WakeSlayer
              • Sep 2005
              • 2069
              • Silver Creek, MN
              • 1968 Mustang
              Re: RE: To winterize or not
              This is a great point of reference. Florida. This seems to happen more than every so often the last few years, if memory serves.
              the WakeSlayer
