cracked cooling water strainer cup
  • gatorgates
    • Aug 2003
    • 112
    • Springfield, IL
    The second season I owned my 2003 206, I noticed that the plastic "cup" around the fresh water strainer was cracked. Replaced it under warranty with no problems. Three years later, I discovered that the cup is again cracked. Boat has never overheated, and I empty the cup when I winterize. Cup is installed only hand tight. New cup is $43 (!!). Has anybody else had a problem with this part? Any ideas what I might be doing wrong that has caused the issue?
  • Red57Bird
    • Aug 2007
    • 381
    • Raleigh, NC/Lake Gaston
    • 2003 Super Air
    When you winterize, do you run the pink AF through the engine? If so, do you leave it in the strainer bowl? I've heard that the AF will cause the plastic bowl to craze and crack. If this is how you winterize, you should empty the bowl and rinse it out with fresh water.
    2003 SAN (current)
    2003 Chaparral 220 SSi (sold)
    • WakeSlayer
      • Sep 2005
      • 2069
      • Silver Creek, MN
      • 1968 Mustang
      I have heard that about the AF also. One of the alcohols dries it out and makes it more brittle.
      the WakeSlayer
      1968 Correct Craft Mustang
      • behindpropellers
        • Apr 2008
        • 97
        • Chippewa Lake, Oh.
        I always pull the cup off, clean it, and put the O ring around the cup, and put the cup in the cup holder for the winter. I always take the impeller out too, and that goes in the strainer cup. All parts on one place easy to find when it goes back together in the spring.
        Tim
        • CradGen2
          • Aug 2020
          • 1343
          • Horseheads NY
          Yep don't leave the PINK stuff in the cup.
          Call White Lake Marine, use the PN discount. They might have just the cup and not the complete assembly
          • gatorgates
            • Aug 2003
            • 112
            • Springfield, IL
            Thanks for the replies. I do take the cup off and empty it of antifreeze, but I probably don't do a good enough job of rinsing it out. From now on, I will give it a good washing and hope that solves the problem.
            • jasper
              • Feb 2005
              • 195
              Yep, check with White Lake. If they don't have it, try http://skidim.com/prodinfo.asp?number=SHE14380
              • 8122pbrainard
                • Jul 2007
                • 255
                Is this the strainer? About $25 at Mcmaster
                http://www.mcmaster.com/#inline-strainers/=4d2bhq
