What's the point of the black PVC pipe (next to the tape measure in the pic)? The length is such that it is almost long enough to reach the bottom of the ballast tank. Isn't this just the overflow so that when the tank is full the water will start flowing out the side of the boat via this hose? Is the length of the PVC critical? I have purchased the elbow to make the repair and was planning on cutting the black PVC pipe off and bonding it to the new elbow. But this will make the black pipe +/- 1/2" shorter. Will it matter?
RE: Ballast Tank Fix
Cut that system out, Flipside. You will be happy you did come Springtime.the WakeSlayer
1968 Correct Craft Mustang
Yes. and ballast puppies.the WakeSlayer
Re: RE: Ballast Tank Fix
Originally posted by WakeSlayerYes. and ballast puppies.2016 SAN 210
2006 SANTE sold
2001 SAN - sold
1991 Sport Nautique - sold
RE: Re: RE: Ballast Tank Fix
I did mine last winter too. Then my buddies saw my system and I ended up doing two more. It smokes the old system to say the least.2001 Super Air Nautique
Python Powered
100 Amp Alternator
Dual Batteries
Many upgrades coming...
Mine did not have them. I had the little panel below the throttle. My friend had a system put in his SV211 and they put the rocker switches for the ballast puppies where the dials were. I would not hook a newer ballast set up to the electronic control panel. You have to add some relays etc and they are just too problematic, in my opinion.the WakeSlayer
No problem at all. And fast !the WakeSlayer
