Instead of fogging or spraying cylinders...
  • Nordicron
    • Sep 2009
    • 557
    • Madison, WI
    Ok this whole fog or not fog or spray oil into the cylinder thing has been brought up dozens of times. This year I just sprayed oil in each cylinder but next year I may try this. Has anyone done it? Good? Bad?
    I got it from yesturdays boattest.com email here is the link and paste:
    Winterizing a Fuel Injected I/O Sterndrive Engine
    By Paul Esterle
    Most winterizing articles simply state “fog the engine’. This is true for carbureted engines but a different technique is used on fuel injected engines. To properly protect the internal engine components from rust and corrosion, you still need to run an oil-rich mixture through the engine; you just do it a little differently. This information was gleaned from a MerCruiser service bulletin.
    Step #1:To start, you mix one quart of Mercury 2-cycle outboard oil with 2-1/2 gallons of gas. Add about 2 to 3 ounces of fuel stabilizer and mix well.
    Step #2: Remove your fuel water separator canister and replace with a new one. Before screwing the new canister in place, fill it with the gas/oil mixture.
    Step #3: Disconnect the fuel line from the tank and place it in the gas can with the oil/gas/stabilizer mix.
    Step #4: If the boat is hauled out, attach muffs to the lower unit using antifreeze.
    Step #5: Start and run the engine until you’ve emptied the gas can. Run the antifreeze through the engine at the same time. You should have reached the engine’s operating temperature, the thermostat should be open, and the pink stuff should have circulated nicely in the block. Remember to use -60 or -100 marine antifreeze, it has corrosion inhibitors that the -50 pink stuff doesn’t have. Don’t use automotive antifreeze -- it is poison to pets and wildlife [to say nothing of people, and CSI folks say it is hard to detect in autopsies.—Ed.] Store the stern drive in it’s down position to avoid permanently deforming the rubber transom boot.
    Step #6: Book a winter getaway in someplace warm.
    http://www.boattest.com/Resources/vi...px?NewsID=3884
    RE: Instead of fogging or spraying cylinders...
    The Fuel system on a PCM engine is a little different than on a Mercrusier engine. The low pressure pump on the PCM system flows a lot more fuel than the engine demands, even at max RPM, at wide open throttle.
    Most of the gas-oil premix you made will just be pumped into the gas tank.
    If you are working on a PCM engine, follow PCM recommendations.
    If you are working on a Mercrusier, follow Mercruiser recommendations.
    • Hollywood
      • Sep 2003
      • 1930
      • WIIL
      I love all the "should"s. :???:
      How long would it take to burn 2.5 gallons of fuel at idle???
      • Nautiquehunter
        • Jun 2008
        • 2080
        I have a 08 catanium 343 the PCM instructions specifically states not to run fogging oil through the cats.
        They recommend pulling the plugs and spraying. I dont see ant time advantage with the Mercury way.
        I think it would be easier to pull the plugs. As DanielC said you cant go wrong following the manufacturers directions.
          My 1997 Ski Nautique uses about 3 gallons per hour, pulling a girls practice with our ski team. One or two girls on swivel skis, 6 to 8 girls in a chorus line, and some idling at the dock.
          • bchesley
            • Feb 2006
            • 1252
            • Tyler, Texas
            What a dang juggling act. Just pull a vacuum line and start fogging through it. You will bypass you sensers and go straight to the intake plenum to the cylinders.
            2001 Super Air Nautique
            Python Powered
            100 Amp Alternator
            Dual Batteries
            Many upgrades coming...
            • JUST-IN-TIME
              • 293
              • ON YOUR BOAT
              Re: RE: Instead of fogging or spraying cylinders...
              what about the MAP sensor??
              you should never fog any efi motors through the intake
              merc has the best way
              all boats should have a water fuel separator on it, if no install one asap, it will save you guys one day
              i use the mercs for mercs
              PCM, i pull plugs out and rotate the motor by hand over 4 times
              HUMAN BUILT = HUMAN FIXED
              switchbait.com
              • tadelfio
                • Oct 2007
                • 172
                • Bullard, Tx
                RE: Re: RE: Instead of fogging or spraying cylinders...
                I believe my dealership uses a fuelstabilizer/fogging solution mixture when they winterize. Not sure what it is but i do not think they fog the engine the traditional way.
