How to change transmission fluid in 1998 Sport Nautique?
  • Jimhunter
    • Jun 2007
    • 35
    I can't find any directions on how to do this. Please help.
    Thanks!
    Jim
  • Quinner
    • 2246
    • Correct Crafts
    RE: How to change transmission fluid in 1998 Sport Nautique?
    You will need a pump to suck the fluid out the dipstick hole, about 2 quarts.
    Best pump out there is the Suck-up. Replace with Dexmerc trans Fluid.
    • SNobsessed
      • Nov 2008
      • 60
      An alternative to the suction pump is a gallon push-pump with a plastic tube extension. This is what I use. You can get them at a beauty supply store. Got the plastic tube extension at the hardware store. Total cost $3.
      As far as directions, just get the pickup tube as close to the bottom as you can, put back in the exact volume that you remove. Use Dexron III.
      • Jimhunter
        • Jun 2007
        • 35
        Thanks, guys.
        This is the last step to winterize my boat.
        Happy Holidays,
        Jim
        • AirTool
          • 4049
          • Katy, Texas
          I"m not trying to be a wise guy....but my connection is SLOW at my vacation retreat.
          There are plenty of threads on how to and how not to change the tranny fluid. Use the search feature.
          • east tx skier
            • 1561
            • Tyler, TX
            Capacity on the power plus is 2 qts. Don't overfill. Put in as much as you are able to remove.
            • AirTool
              • 4049
              • Katy, Texas
              Agree...and if you change it HOT....and suck out more than 2 quarts...put only 2 quarts back in and run it/check it. I've changed mine several times. I always get 2 1/4 hot and put back only 2. Transmission fluid expands alot with with heat.
