Went down to the Napa store looking for some Perfect Seal as mentioned in my owner's manual, although I ended up coming home with hopefully an equivalent thread sealant made by Permatex since Napa didn't carry the Perfect Seal stuff. Does anyone know/used this stuff before to create a seal on all the water and gas line drain plugs involved in the winterization process? Stuff says it's good for items up to 2" and max temp of +400. Exact product name is 'Permatex High Temperature Thread Sealant Automotive Grade'. Thanks again for all the help.
RE: Perfect Seal Equivalents
It should work What year is your boat. If it has a knock sensor in one of the holes you don't want to use any sealant or lubricant as it will mess up the sensors ability to sense knocking.Nautiqueless in San Diego
Re: Perfect Seal Equivalents
Originally posted by ponycarWent down to the Napa store looking for some Perfect Seal as mentioned in my owner's manual, although I ended up coming home with hopefully an equivalent thread sealant made by Permatex since Napa didn't carry the Perfect Seal stuff. Does anyone know/used this stuff before to create a seal on all the water and gas line drain plugs involved in the winterization process? Stuff says it's good for items up to 2" and max temp of +400. Exact product name is 'Permatex High Temperature Thread Sealant Automotive Grade'. Thanks again for all the help.
http://www.permatex.com/documents/td...tive/59214.pdf
Originally posted by AirToolOriginally posted by ponycarWent down to the Napa store looking for some Perfect Seal as mentioned in my owner's manual, although I ended up coming home with hopefully an equivalent thread sealant made by Permatex since Napa didn't carry the Perfect Seal stuff. Does anyone know/used this stuff before to create a seal on all the water and gas line drain plugs involved in the winterization process? Stuff says it's good for items up to 2" and max temp of +400. Exact product name is 'Permatex High Temperature Thread Sealant Automotive Grade'. Thanks again for all the help.
