12v accessory outlet
  • wcherashore
    • Sep 2009
    • 190
    • San Diego, CA
    The 12v accessory outlets have gone out in my boat (2000 Air), any suggestions?
  • bchesley
    • Feb 2006
    • 1252
    • Tyler, Texas
    RE: 12v accessory outlet
    You can get a replacement. Check the whitelake marine link above and get a discount.
    2001 Super Air Nautique
    Python Powered
    100 Amp Alternator
    Dual Batteries
    Many upgrades coming...
    • xlair
      • 694
      • Wisconsin
      you should check the fuses/breaker first
      2001 Pro Air Nautique
      • Hollywood
        • Sep 2003
        • 1930
        • WIIL
        Try to keep dimes out of them...
        • M3Fan
          • 1034
          Tell me about it - been through that on both of our cars already.
          2000 Ski Nautique GT-40
          2016 SN 200 H5
          www.Fifteenoff.com
          • 01bigair
            • Apr 2009
            • 97
            • Kirkland, WA
            I have an 01 Air and want to know what the 12V button is for. Whenever I plug anything into the 12V outlet it works without pushing the botton on the dash. Is this working correctly. The green light does come on when buttom is pushed, just doesn't seem to control the outlet.
            • WakeSlayer
              • Sep 2005
              • 2069
              • Silver Creek, MN
              • 1968 Mustang
              Do you have any other receptacles in the back of the boat? Mine runs the one in my dash, but I thought at some point they added additionals, not sure if that is the case on yours.
              the WakeSlayer
              1968 Correct Craft Mustang
              • wtrskii3156
                • May 2006
                • 39
                • Virginia
                Isn't the 12v switch on the dash the button for a 12v accessory? There are wires behind the dash you can hook up any 12v accessory to. Lights, etc. I could be wrong...
                • 8122pbrainard
                  • Jul 2007
                  • 255
                  Better get the volt meter out. "xlair" advice is good - check before buying unneeded parts!
                  • wcherashore
                    • Sep 2009
                    • 190
                    • San Diego, CA
                    I went to check the breaker box under the dash, but it had a disclaimer on it that might as well been a skull and cross bones, warning non certified technicians to stay out. I guess it served its purpose because it kept me out of there for the time being...
                    Should I decide to open it up, what am I looking for? this forum has pointed out that the 12V button on the dash controls the accessories added to the dash and not the actual 12v outlet
