Thanks for the previous help! But I've got a few more:
What weight oil for the Chevy 330 engine? What is the capacity? Told 25/40 but can't find it at parts store.
I was also advised to use oil extractor on this engine. Agreed? I suppose I go down the dip stick hole?
Also, where are all the drain plugs on this engine? I found one on each side of engine (port side with knock sensor). Are there others? I also drained the filter, intake hose, heater hoses and heater, and whatever you call those huge plugs on each side.
Thanks guys!
Thanks guys!
