I purchased a second-hand slalom switch, and needed to buy an extension cable from Perfect Pass to connect the switch to the control module of my Plus system. The cable that came that connects to the control module is a 3 pin harness, but the female outlet on the module is a 4-pin. Anyone else run into this issue? Did the module change in more recent yrs that anyone knows of? (interesting too, back behind the dash, bundled with the other PP wires, was a 4-pin male that wasn't plugged in, and does fit into the "slalom-switch outlet." Could it be hard-wired and just needs a connection from the switch to the wiring harness at the motor somehow?
Thanks to anyone with any info!
Todd
Todd
