Ok, so we are forcast to have some cold weather in Texas, possibly some nights in the low 20's. My garage is attached to the house and I keep one of those electric heaters plugged in and set to kick on if the temp drops below 40, so I should be fine.
However, I would like to know how to drain the engine for two reasons (1) to know and (2) to know how to do it in the event we were to loose power for an extended period during a cold snap at some point.
I have seen several post about 5 plugs on the Fords, but I wanted to know if anyone knew the number and location for the Chevy Apex. Looking at the engine, I think I see 2 huge brass plugs at the rear ends of each manifold, 1 small brass plug on the lower side of the block, and 1 small brass plug on the lower opposite side of the block (also having a sensor attached to it..is this the knock sensor?). But I have not located any others?????
Also, if I pull them is there anything special I need to do when I replace them...they appear to have thread tape on them now, and is there anything special for taking out and replacing the one with the knock sensor???
Thanks in advance!
Thanks in advance!
