2003 Gauge Problem
  • Eggie
    • Jan 2004
    • 110
    • PA
    2003 Gauge Problem
    Both of the 5" gauges on my 206 had slight cracks on the lens when I took delivery of the boat. Replacement is covered under warranty but I was wondering if it's worth having them replaced as in something else might get screwed up when they tear apart the dash or if you guys would recommend leaving them as is. Also, if they are replaced, will I lose my historical hour count or is that stored somewhere else ?
    Jeff
    2003 Ski Nautique 206 Limited, FCT, Excaliber 330, Midnight Blue - Silver Cloud
  • Frost
    • 161
    You can have your dealer replace the gauges, everything should go fine with the replacement. It's a simple swap out, also you will not loose your engine hours. When you first power up the engine it will place the hours back on the gauge.
