I have been using this site for roughly 6 months and credit it to educating me about my families boat. In the past six months I have returned home from college and used our boat a tremendous amount (80 hours) and this site has helped me become more familiar with the technical aspects of the boat which I want to learn more about. The reason I mention it is because I have been interested in adding an upgrated ballast system and have learned a ton from reading past and current threads on the topic. Now that I have become fairly educated about this I think I know what I want and understand what is required of the install, etc, etc
I am about ready to pull the trigger and am hoping your comments will help me determine what to do. There is a wealth of experience with similar projects on this site and hope you will share it with me. As mentioned, the boat is a 2000 Air Nautique and I am currently considering the following system:
ripping out the stock hard tanks (I have finally resolved to do this after reading many past threads and learning they have to come out to replace my steering cable anyway)
replacing them with a larger bag and more likely a two bag system in the trunk space replacing the hard tanks (600-1000lbs)
in addition, I will add a sack in the ski locker (rear seat sack bag will fill out the space best maybe 400-500lbs?)
I plan on venting the ski locker bag using the drain/ thru hull on the gunnel for the glove compartment/ cooler and venting the rear bags using the factory thru hulls for the stock hard tanks (perk of ripping out)
I had thought that each bag (if I desired completely independent control) or at least the ski locker and trunk sacks would require seperate thru hulls, but have since learned that this may not be the case if impeller pumps are used (can three pumps feed off a 1" scoop style thru hull)? However, aerators would require at least two one for filling and emptying. I plan on using the factory thru hull and possibly another one or two if needed
regarding pumps.... at this point I exclusively wakeboard and do not wakesurf. This is important because I had thought I would have a single pump that tees to two seperate bags in the trunk and possibly add a second pump if I decided to since I would not be independently controlling the rear bags often (I could use a manual switch).
my options for pumps are of course aerator v. impeller and also as mentioned, whether to have dedicated pumps and possibly thru hulls to each bag. Clearly for aerators I will require double the amount of pumps as a similar impeller system (one for filling one for draining) but consider my options are either:
A:Locker and trunk run independently and trunk sacks share a pump
B: all sacks have dedicated pumps
I also use my boat in salt so I am wondering if either pump style is more durable in this application.
This is a long post so I will sum up my questions:
1.can multiple pumps be effectively fed by a single thru hull
2. aerator v. impeller
3. dedicated pumps in the trunk v. shared pump and teed plumbing
4. durability of pump styles in salt
any and all advice is greatly appreciated
