I have a 1985 2001 and I am thinking about changing out the original heads with the GT40 heads. I understand you gain about 40-50HP ( is this accurate?). I also understand though if you can find some of the 351 heads from the 69-70 era that they are actually better (true?). The only change you have to make with the GT40 heads is a timing adjustment, is this true with the 69-70 heads. Also, where is the best place to get a deal on the GT40 heads? Any info is helpful.
