Engine Oil for GT-40. . .Straight 40w?
  • JWAT
    • 527
    • NE Indiana
    • 1997 Super Sport/Super Air Nautique 2008 Super Air Nautique 210
    I am getting ready to change the oil in my '97 Super Sport with a GT-40 motor. On the tag on the engine it says to use straight 40w oil? Is this what everyone else uses? If not, what else do you use? I've heard a lot of other people use 15w-40. Straight 40w is hard to find sometimes and I just wanted to see if this is definitely what I should be using. Also, how many quarts of oil does it usually hold. . .5 or 6?
    And lastly, should I use straight 30w for the v-drive oil? Thanks.
    2008 Super Air Nautique 210TE
  • Dr.John
    • May 2004
    • 225
    • Austin, USA
    • 2001 Sport/Air- SOLD
    PCM says 40w40 above 60*, 30w30 below 60*.
    see: http://www.planetnautique.com/index....ewtopic&t=1873
    and: http://planetnautique.com/index.php?...=trans%2Bfluid
    \'01 Sporty Air Nautique
    • skinautique
      • 1749
      • Colorado
      straight 30 or 40 weight high performance oil for both the engine and the vdrive. You will probably get 5 quarts out of it but it doesn't hurt to buy a sixth just incase you need to use 5.5 quarts (If you don't use it all, you have some for the next oil change)
