Spring Maintenance!
  • rugdr
    • Sep 2008
    • 98
    Spring Maintenance!
    Hello everyone! I am about to do my spring maintenance and I have two questions about my 2008 SANTE 210...
    1. Which impellar do I need to purchase for the water pump?
    2. What kind and how much tranny fluid do I need for my v-drive unit?
    Thanks for the help!
  • jaybird
    • Oct 2008
    • 516
    • North Alabama Lake Weiss
    The impeller may depend on which engine you have. Excal 343 or ZR6.
    You can find the impeller you need in the PCM Engine Manuals on this site under manuals.
    You will need both tranny fluid and V-drive fluid, not the same. If you have a v-drive boat the transmission and V-drive are independent units. It is not necessary to change the V-drive fluid unless it appears contaminated. Donโ€™t put the wrong fluid in either or you will have problems.
    Tranny is Dexron III, the V-drive is Mobiltrans SCH50 but I believe it has been discontinued but has a replacement number now. Good luck finding the V-drive fluid. I think it takes about 2 -quarts but rarely is it sold in less than 5 gallon containers.
    2012 Team Ski Nautique ZR409
    2011 Sport Nautique 200
    2008 SANT 230
    2003 Air Nautique 226
    1988 Martinique
    1979 Nautique
    1978 Tique
    1976 Tique (First New Boat)
    • jaybird
      • Oct 2008
      • 516
      FYI,
      Mobiltrans SCH50 is replaced with Mobil Delvac Synthetic Transmission Fluid 50 avaliable from Grainger Ind. Supply in 1 gallon containers only. Granger #1MRG2
      2008 SANT 230
      1988 Martinique
      1979 Nautique
      1978 Tique
      • rugdr
        • Sep 2008
        • 98
        Thanks Jay. I have the 343, so I'll see what I can dig up. Also how much of the tranny fluid will it take because the vdrive is fine. Thanks again!
        • jaybird
          • Oct 2008
          • 516
          less that 2 quarts
          2008 SANT 230
          1988 Martinique
          1979 Nautique
          1978 Tique
          • kevfran99
            • Sep 2008
            • 335
            • ATL
            • 08 210 SAN Team
            Please do us a DIY on the trans fluid change for the 343. I would love to see pics and direction s on how to do this. Thanks!
            '08 SAN 210 Team Black w/Patriot red top stripe-Tow Biminis over the tower-4 under water transom lights-hot/cold shower-crest carpet-full throttle steering wheel-extra 6 channel JL amp-Pro 80's-WS420-fiberglass sub enclosure-led'd vents-Chromax Letters-and Tinted windshield for now......
            Tow Vehicle--05 GMC 2500 Crew Cab Short Bed 6.6L Duramax/Allison with a few mods
            -GO DAWGS!-
