Quick ballast question
  • mevirga
    • Feb 2010
    • 36
    • Santa Cruz, CA
    Hello-
    I'm installing a supplemental and independent ballast system that draws from the raw water intake on my '99 Air. It will fill/drain via a reversing puppy pump plumbed to 2 bags. I will TEE a vent line from each bag into the bilge pump lines. Question: do I need check valves on the vent lines?
    Thanks for the help.
    Mike
  • Chexi
    • Apr 2025
    • 2119
    • Austin
    • 2000 SAN
    I would be more worried that your sac overflow would fill your bilge. I would think you would need check valves on both the bilge line and the vent, unless you have them oriented where down is always out.
    Now
    2000 SAN
    Previously
    1999 Air Nautique
    1996 Tige Pre-2000
    • mevirga
      • Feb 2010
      • 36
      • Santa Cruz, CA
      Yes. Thanks Chexi. You helped me answer my own question.
