No Nav, anchor or courtesy lights working
  • jasage
    • Jan 2010
    • 3
    I can not get my nav, courtesy or anchor lights to work. The breakers are not tripped. When I push the corresponding button on the pad, I do not hear the relay open/close on the breaker box. If you listen carefully you can hear a little "click" when the button makes the circuit. Do I have a bad pad or possibly one of the relays? Can it be fixed without having to order an expensive pad. Anyone had this problem? Thanks
  • 93nautique0710
    • Aug 2009
    • 173
    • east tn
    • 1993 ski nautique 196
    get your self a test light and check if u have power at the breaker and when on power coming out just cause it clicks dont meen it isnt bad if u have power check grounds you can do that with the test light to just put the other end on power
    • highrock
      • Sep 2008
      • 206
      • Salisbury, NC
      • 1995 Ski Nautique (2017-Current) 2015 G21 (2016-Current) 2010 230 (2012-2016) 2008 210 (2008-2012)
      What model boat is it? I have an 2008 210 and this happened to me. It was solved by replacing the Gateway box.
      2010 Super Air 230
      2008 Super Air 210
      • jasage
        • Jan 2010
        • 3
        It is a 2000 SAN with only 149 hours. Corrosion could be an issue as I don't think it has seen the inside of a garage since it arrive here. What and where is the gateway box? I am trying to bonaroo the boat for the upcoming season. Thanks
        • jasage
          • Jan 2010
          • 3
          I replaced the key pad and it corrected the problem.
