I had the dealership (buxton) winterize the boat and put all hoses back so in the spring all i had to do was an oil change. My question is what type of oil do you use for the excaliber 330. They recommend 5 quarts 15w-40 for diesel engines (valvoline). Also, when i take it down to the lake, hopefully this weekend and run a check on everything i have the following To Do Checklist.
-transmission fluid
-vdrive fluid
-water strainer
-hose leaks
Can you make any suggestions on what else to check.
Thanks
-transmission fluid
-vdrive fluid
-water strainer
-hose leaks
Thanks
