Spark plug replacment help please?
  • Scar13
    • Mar 2010
    • 9
    • 2004 210
    Good day everyone,
    I have 2004 210, with a PCM 5.7 liter motor and its time to change the plugs..
    Research and manual point to a rp0300100 plug at 90$ for a set of 8?
    Is that correct is there no other plug I can use instead of such a expensive spark plug?
  • jaybird
    • Oct 2008
    • 516
    • North Alabama Lake Weiss
    plugs
    how many hours are on your engine?
    2012 Team Ski Nautique ZR409
    2011 Sport Nautique 200
    2008 SANT 230
    2003 Air Nautique 226
    1988 Martinique
    1979 Nautique
    1978 Tique
    1976 Tique (First New Boat)
    • ponycar
      • Jul 2009
      • 52
      • Dallas, TX
      • 2005 196
      Your correct on the price. I pulled the ones out in my boat and Napa set me up with a set of platinum plugs around $8-9/plug. What came out was AC 41-932, but they said they didn't make those anymore and gave me a replacement. I probably wouldn't try to cheap out on these, which overall are pretty cheap if you divide the dollars/year of use you get out of them. Instead of Napa go with White Lake which give you a discount for being a member here I believe.
      05' 196
      • 93nautique0710
        • Aug 2009
        • 173
        • east tn
        • 1993 ski nautique 196
        Originally posted by ponycar View Post
        Your correct on the price. I pulled the ones out in my boat and Napa set me up with a set of platinum plugs around $8-9/plug. What came out was AC 41-932, but they said they didn't make those anymore and gave me a replacement. I probably wouldn't try to cheap out on these, which overall are pretty cheap if you divide the dollars/year of use you get out of them. Instead of Napa go with White Lake or Discount Marine both of which give you a discount for being a member here I believe.
        If it was mine I would put ac delco plugs back in whitelake does have them at highly recommend but if u want to see if u can save money cross the spark plug number to Ngk. Ngk make most of the delco plugs anyway and your cutting out the second party for the same quality plug
        • ponycar
          • Jul 2009
          • 52
          • Dallas, TX
          • 2005 196
          Did some searching and it looks like the AC 41-932 plugs were replaced by AC 41-993.
          05' 196
          • 93nautique0710
            • Aug 2009
            • 173
            • east tn
            You can get ac41-993 at summit racing for 6.25 a plug and cdiautoparts.com has them for 5.50 at that price just stay with delco
            • johnboyy7
              • Oct 2009
              • 409
              • houston
              How often are y'all changing your plugs?
              04 SANTE 210
              89 SPORT
              • Scar13
                • Mar 2010
                • 9
                • 2004 210
                500 hours are currently on the boat..
                On whitelake all I see is the rp030010 set ?? Where do you see 41-993??
                Perhaps I should just call AC-delco and ask for the 41-993?
                • 93nautique0710
                  • Aug 2009
                  • 173
                  • east tn
                  go to cdiautoparts.com they sell delco and motorcraft oe parts the full set of them plugs would cost like 45 bucks for the 41-993
                  • Scar13
                    • Mar 2010
                    • 9
                    • 2004 210
                    I am picking up the ac's at autozone!!
                    Anyone know about plug wires and what set I would need?
                    • AirTool
                      • 4049
                      • Katy, Texas
                      Try a set from a 98 chevy pickup truck.
                      • Scar13
                        • Mar 2010
                        • 9
                        • 2004 210
                        ??? I am not sure I understand your post??
                        • AirTool
                          • 4049
                          • Katy, Texas
                          I'm not sure if marine plug wires are special or meet the "J" whatever spec. From a fit/function standpoint, the wires from a 98 Chevy pickup w/5.7R engine whould work if the routing is the same. My concern (for routing) might be that the paths are different because of the exhaust manifolds. Find a late 90s truck with the vortec engine and the flat top distributor cap and take a look.
                          AC might also have a marine lookup catalog.
                          About to travel - no more posts from me today.
                          • Scar13
                            • Mar 2010
                            • 9
                            • 2004 210
                            ahh ok
                            I was thinking might know the part# I could get from a auto parts store?
                            • kalexander0922
                              • 3
                              • Olathe, KS
                              • 2005 Air Nautique 226
                              May be a lame question, but I am considering trying to change these out on my boat myself. I have always changed the plugs on my cars, but I was taking a look and holy cow that looks tricky to get that far down and around to them. Am I missing something obvious? Does anyone have any advice on the matter? Much appreciated.
                              In reply to the posts, I can confirm that the correct plugs are 41-993 for the 6.0 ZR6 motor...just not sure how I'm gonna get them changed
