First time posting, I just bought a 1990 ski nautique. I have a 1993 since 1995, I bought this one as a second boat.
I got a real good price on it. It needed lots of work, everything that was broke I fixed. The guy I bought it, said
it was running hot. I took the the thermastat out, cleaned exhaust, changed the impeller. Checked the incoming
water and it was clear. Ran it at home for 30 mins with water on and never heated up. Today I took it out
to check my work. It did over heat, my concern is, it would go to 200 when idel. As soon as I would run it to
30 mph or any speed, it would drop down to 140. It does have a heater, could the heater or water pump
or some line be partially obstructed? It has to be simple, or not. The motor has no water in it, I did clean
out the opening in the exhaust, it seams like the water may not be coming out. Any ideas, I could use
some help
Thanks Kevin
some help
Thanks Kevin
