Key Pad Bypass
  • KenG
    • Oct 2006
    • 29
    • Minnesota
    • 1991 Ski Nautique 1997 Ski NautiqueW/ GT 40 2006 206
    Key Pad Bypass
    Last year we had an issue where our 2006 206 would not start. Turned out to be the teather switch. Anyway it got me to thinking that I need a bypass for the Keypad if it were to go bad if nothing else just to get it off the lake. Has anybody made one and if so how?
    PCM Excal DBW
    Thanks
    2006 Ski Nautique 206
    1997 Ski Nautique CB
    1991 Ski Nautique
  • dwsa
    • Sep 2005
    • 134
    Keypad Bypassed
    I have just done this on my 2001 SN after my keypad failed. I have been able to repair my keypad with some rework on the printed circuit board (PCB). As a precaution I have wired in a bypass, its a 3 position key switch mounted on the side console, OFF/ON/START and wired directly to the battery so it also bypasses the Bilge Pump OFF/ON/AUTO switch which can also fail and leave you stranded. The ON circuit powers the Ignition Run Purple wire and START powers the Yellow/ Red wire next to it for the starter motor. Only draw back with the keypad out of circuit is that the radio on the ACC circuit does not power on, nor will the Blower or Horn as switch is out of circuit, but hey! the engine starts and runs! I will post a photo after the weekend.
    • dwsa
      • Sep 2005
      • 134
      Something else
      I did not bypass the safety switch!! That could still leave me stranded but at least the boat can't get away from me!
      • johnboyy7
        • Oct 2009
        • 409
        • houston
        The last couple of times I've taken the boat out it has taken awhile before it will start/ fire. Like there is no
        grunt or anything and then just like that, bam it's running. The only theory I have is I'm turning my pergo switch off and it's taken the computer a few minutes to
        boot up. Thoughts?
        04 SANTE 210
        89 SPORT
        • KenG
          • Oct 2006
          • 29
          • Minnesota
          Thanks, I am thinking I will purchase a ten pin plug and wire a keyed ignition switch in a box to it. If needed I would remove the boat wiring at the engine harness and plug in my temporary harness. This would also take the boat computer and gauges out of the circuit to avoid damaging them. I think all I will use is 3 wires.
          1, Battery from the engine harness
          2,Ignition from the swich to the purple/white wire of the harness
          3, Start position on the switch to the yellow/red wire of the harness.
          I know I will not have any gauges etc. but it would get the boat back on a trailer.
          Does this seem right?
          1991 Ski Nautique
          • KenG
            • Oct 2006
            • 29
            • Minnesota
            The way I am planning to do this the tether switch will not be in the circuit. I'm not saying its right but I have never used it on any of my boats anyway (don't know anyone that does), but if you do thats great and we all probably should.
            1991 Ski Nautique
            • dwsa
              • Sep 2005
              • 134
              HI
              This will not work as your engine requires the ECM (computer) to be powered in order to run. Powering the purple ign may power the ECM but you will also need battery power, which you could get with a lead from your box to the battery but this would be messy! I think my solution is easier and well engineered. Will post a photo soon. Cheers Greg
              • dwsa
                • Sep 2005
                • 134
                Second thoughts
                I apologise...your solution will work as you do have a BAT feed in the engine harness and therefore an elegant solution with the plugin key box. Cheers Greg
                • ers906
                  • Feb 2010
                  • 921
                  • Phoenix AZ
                  Ken
                  Please post pictures and materials list of the bypass. I have been told I am a bit of a "glass half empty type of a guy" but I consider it prudence not to be caught with no way to get back to shore
                  Thanks
                  Eric
                  Eric, Phoenix AZ
                  G23 550 hp (finally here)
                  2002 Super Air
                  • KenG
                    • Oct 2006
                    • 29
                    • Minnesota
                    Originally posted by ers906 View Post
                    Ken
                    Thanks
                    Eric
                    I will, it will probably be next week. Another benifit to this is if you do your own work you can bypass all but the engine controls to isolate a problem in the time it takes to loosen a hose clamp and switch a plug.
                    1991 Ski Nautique
                    • dwsa
                      • Sep 2005
                      • 134
                      Repaired keypad and just in case keyswitch
                      Oh! and new Faria gauges installed!!
                      • KenG
                        • Oct 2006
                        • 29
                        • Minnesota
                        pictures
                        Ken
                        Thanks
                        Eric
                        The "bypass" works great on my boat, however a friend of mine owns a Nautique dealership and we made one for him also. The plug on a 2008 is differant. I think a 2007 is the same as my 2006(could be wrong about this). The bypass fits nicely in a small tackle box I keep in the boat.
                        1991 Ski Nautique
                        • KenG
                          • Oct 2006
                          • 29
                          • Minnesota
                          Ken
                          Thanks
                          Eric
                          The switches I already had, the plastic box is a project box from Radio Shack $4.00, the plug is the expensive part I think about $60.00 from PCM. The plug came with about 16 inches of wire on it, wired it to the switch and shrink tubed the wires. Drilled holes and mounted in the box.
                          If I didn't have the ignition switches I would have used a spst and momentary contact switchs.
                          1991 Ski Nautique
                          • KenG
                            • Oct 2006
                            • 29
                            • Minnesota
                            Ken
                            Thanks
                            Eric
                            If I didn't have the ignition switches I would have used a spst and a momentary contact switchs.
                            1991 Ski Nautique
                            • johnboyy7
                              • Oct 2009
                              • 409
                              • houston
                              Would someone mind telling me exactly how to do this please.
                              04 SANTE 210
                              89 SPORT
