Does anyone have the measurements of the Jabsco Ballast puppies
  • ers906
    • Feb 2010
    • 921
    • Phoenix AZ
    Does anyone have the measurements of the Jabsco Ballast puppies? Height width depth? (witht he fittings) Need to know if they are going to fit where i am hoping for my ballast system
    Eric, Phoenix AZ
    G23 550 hp (finally here)
    2002 Super Air
  • Chexi
    • Apr 2025
    • 2119
    • Austin
    • 2000 SAN
    From the brochure:
    3-5/8" (93mm) high (deep I guess)
    7-1/8" (182mm) long
    4-3/4" (120mm) wide
    Now
    2000 SAN
    Previously
    1999 Air Nautique
    1996 Tige Pre-2000
    • ers906
      • Feb 2010
      • 921
      • Phoenix AZ
      Thank you. I probably should have been able to find the specs online but had the girlfriends 4 year old daughters bday at the zoo today. Fun Fun
      Eric, Phoenix AZ
      2002 Super Air
      • Chexi
        • Apr 2025
        • 2119
        • Austin
        • 2000 SAN
        No problem. Glad to help. I actually needed those measurements anyway.
        Now
        2000 SAN
        Previously
        1999 Air Nautique
        1996 Tige Pre-2000
        • wcherashore
          • Sep 2009
          • 190
          • San Diego, CA
          Chexi,
          Keep me posted on where you're going to mount yours.
          • ers906
            • Feb 2010
            • 921
            • Phoenix AZ
            I am finding a hard time figuring out where to mount mine as well. I build a bracket for over the front portion of the transmission (under the middle seat) for three of my pumps, and will probaby place the fourth under the starbord back seat far enough back that watter cannot drip on the pump unit. I was trying to figure a way to mount them in the engine compartment, either with a bracket over the exhaust manifold or mounted to the back of te hind seat but I couldnt find a way that would make me happy, not decrease the ablility to reach the shut off valves and the abliity to see the engine compartment. I have the PCM excaliber 330 hp, so I am not sure if it is the engine size which makes it difficult (since Ihave seen others mount them there). ANy advice?
            Eric, Phoenix AZ
            2002 Super Air
