I had a compression test done on a PCM 5.7L engine. The results were as follows:
1 190
2 190
3 195
4 230
5 220
6 220
7 190
8 190
Two things about these results I have questions on:
- Master Engine Specs of this engine (attached) show compression pressure range from 130-215 psi. Are my 220/230 readings too high, and why?
- The differential in pressure between cylinders is greater than 10% in several instances (I had read somewhere that the variation shouldn't be more than 10%). Is this bad?
I would be interested in knowing anyone's thoughts on this.
Thanks.
1 190
2 190
3 195
4 230
5 220
6 220
7 190
8 190
Thanks.
