I removed the PCM decals from gunwales, and one side left a yellow stain from the adhesive or dirt that was trapped under the sticker. How deep into the gel could a stain go? I wet sanded the spot with 1500 and it didn't do the trick. I was thinking about starting with 1,000 and trying it again, but won't bother if the gel could be impregnated too deep.
I would try some acetone before I did a lot of sanding. Gel is hard, but it is porous. The acetone may dissolve away
some of the glue in the pores. Acetone won't hurt gell coat. I also would probably let the sun do its thing before I did a lot sanding. The sun will often lighten up mild staining on both the gell coat and the upholstery. My $.02. Take it for what it's worth.
BKH2001 Super Air
Try Comet but don't rub it
You can try a poultice of Comet. The bleach will pull the stain out. Don't rub it off though let it sit on the stain for 15 minutes then rinse it off.Nautiqueless in San Diego
i have heard of this stuff called on off or it may be called on & off but you are going to have to probably get it from a boat dealer and i heard that you just put it on then wait a minute or two and rinse it off and that that removes a bunch of stains and discoloration.. so you might could give that a try.
