Minor exhaust leak from one side of the block?
  • jmo
    • Mar 2006
    • 710
    • MA
    Hey Guys,
    So I was preping my boat for usage, and after putting the impeller back in and firing her up to make sure everything was working, I noticed that some exhaust appears to coming up from between the block and the exhaust manifold on the port side, its not a lot, but its definitely happening. Does this mean I need to replace the gaskets on the manifolds? Is this straightforward outside of being a bit cramped? How big of an issue is this?
    Engine temp was fine, never over 120 while I was running it in the driveway (with a hose supplying the water), seems fine otherwise.
    Nautique super sport (2001) with about 320 hours - GT40.
    Thanks in advance,
    JMO
    2018 Ski Nautique 200 TE, H6
  • WakeSlayer
    • Sep 2005
    • 2069
    • Silver Creek, MN
    • 1968 Mustang
    You could get a torque wrench and check the bolts for correct torque (check the manual for specs), but you likely need new gaskets. It is not too difficult to do.
    the WakeSlayer
    1968 Correct Craft Mustang
    • jmo
      • Mar 2006
      • 710
      • MA
      Thanks wakeslayer- I fired it up again today to try and isolate exactly where the leak is and now it doesn't happen anymore, I guess I'll just keep an eye on it.
      • WakeSlayer
        • Sep 2005
        • 2069
        • Silver Creek, MN
        • 1968 Mustang
        Is it possible you just spilled a couple drops of oil on there while changing it? Maybe it wasn't exhaust at all.
        the WakeSlayer
        • jmo
          • Mar 2006
          • 710
          • MA
          It's certainly possible it was a bit of oil from removing the filter, but since the smoke/steam/exhaust was coming up on the opposite side of the block I'm less inclined to believe that. Could be some spilt RV anti-freeze dried on the block from winterizing.
