My ballast pumps will fill but not empty, I have a 06 210 and have searched the forum for answers but did not find the one i need. I found out there is a safety relay as to where when the ballast gauges read empty the pumps automatically will shut off. My question is how do I bypass this unit so I have to manually shut the pumps off, so I can see if this is where my problem is.
Tags: None
Def. start simple by checking fuses or breakers! I had a fuel pump issue last summer and thought i had it pegged to a bad fuel pump and i ended up being the inline fuse up by the battery that was bad. Now i'm stuck with a $130 fuel pump, bummer!1998 Correct Craft Air Nautique DD
FCT 2 by NDT
Teak Platform Restoration
Re-Carpet Trailer
Oxidation Removal
Install Automatic Ballast System
Re-Decal Boat
Interior Restoration
