After my boat sat for 2 1/2 weeks I found my battery dead. The switch on it was in the all off position. The dealer called me today to let me know he had another 206 do the same thing. He said there is a service bulleton about the small 40 watt amp of the Clarion system being wired directly to the battery and staying on all the time. The temp. fix is to take out the fuse on the positive lead of the battery. The true fix is rewire the amp to a swiched circuit. I don't know if anyone has experianced this but I bet there is.
Clarion Amp Drains Battery
Current
2003 SkiNautique 206 LE Yellow - Black - Silver Cloud
Previous Fleet
2006 Ski Nautique 196 SE Titanium - Black- Silver Cloud
2004 Ski Nautique 206 LE Red - Black - Silver Cloud
1993 Mastercraft Stars & Stripes 190 RedTags: None
You are correct. There is a service bulletin for this problem. If anyone has this issue or wants to check, call your dealer with your hull number to see if you are affected. I am surprised that dealers aren't contacting customers about these issues though. A dead battery is a major nuisance to any boater.
Count me in on the dead battery brigade ......twice....... When I called dealer, he commented that happens when the boat sits. Bummer! I'm going to call again to see if my 206 is in the group (bet it is!) Thanks for the heads up george!2004 Air 206 Limited, Midnight Blue & Titanium, Silver Accents, FCT, Vortec ZR6, Perfect Pass - Dream Nautique!!
1991 Barefoot Nautique, Fire Red & Black, PCM 454 - Power and Comfort!
I had the problem very early in the year (before the bulletin). I figured that the amp was causing the problem, theN the bulletin came out. I your dealer follows the bulletin the problem will be corrected.
Dave2019 Ski Nautique 6.2 arriving soon
16 other Ski Nautiques
3 MasterCrafts
18 Ski Supreme's
1 SlickCraft Squirt Boat
