which grade of fuel to use?
  • Cam003
    • Jun 2007
    • 209
    • Petaluma, CA.
    • 2004 SANTE
    Originally posted by tadelfio View Post
    I'm sure ethanol free gas has been known to cause cancer in the state of California. lol
    So does breathing the air!!!!!
    Anyways i have an 04 SANTE and no manual anyone know what the manual recomends for my 330 excal pmc?
    Our Setup
    • wcherashore
      • Sep 2009
      • 190
      • San Diego, CA
      i've always put 89 grade gas in my GT40, am I blowing it by not using regular?
      Im in CA and alcohol is unavoidable in our gasoline...
      • hourglass
        • Mar 2010
        • 248
        • lower bama
        • 2005 SANTE
        your ex330 likes 87 octane.
        • sean950054
          • Mar 2010
          • 55
          • 97 Ski Nautique 196 98 Air Nautique 06 Air Nautique SV211 Intrepid 339
          Solar Power
          I have given up....I am just going to convert the whole boat to a solar powered vessel. Keep the environmentalists happy.......
            I would use what the manufacture recommends, based on availability. I have a 1997 Ski Nautique, GT-40, recommended octane, 89, no ethanol. Here in Oregon, you cannot get ethanol free gas, and I have not been able to get it for several years, I run 89 octane E-10 gas. My manual does state, that if 89 is not available, you can run 87. The performance of the engine may suffer. I have experienced no problems with the E-10, my boat has over 2245 hours on it. I have also noticed that when I drain the FCC I rarely see any water.
            I believe all GM engines since 2002 are set up to run 87 octane, and I think PCM has issued a recommendation that using E-10 is OK.
            Before modern engines used computers to set the ignition timing, fuel grade choice was way more important. Engine knock, or detonation is very bad for a motor. A modern engine has a "knock sensor" on it that retards the ignition timing to prevent it. This is why a GT-40 may suffer a performance loss using a 87 octane fuel.
            For all practical purposes, octane rating is a measure of how fast the fuel burns after the spark plug has fired. Higher octane fuels burn slower. A high compression engine typically will make the fuel burn faster, therefore they require a slower burning fuel to run right, without knock, a higher octane fuel.
            If you run this high octane fuel in an engine designed to run a lower octane fuel, it burns slower, so the engine does not build maximum cylinder pressure at the same time in the combustion stroke, and you will lose power. It will not hurt anything, but you will use slightly more fuel than the lower octane fuel, and you will spend more money per gallon also.
            • shag
              • 2217
              Ethanol
              Doesn't it actually cost more, and cause more pollution will all the manufacturing that it takes to make ethanol? My experience = before ethanol, no fuel problems in any equipment or engines. After ethanol, fuel related problems - mainly in small gas engines (lawn mowers, chainsaws, outboard motors, etc) but also have had problems in cars, and occasionally in my boats. (Fuel pump failure, fuel line de-lamination). Seems as though there is a correlation there.....
              My .02
              • swc5150
                • 2240
                • Eau Claire, WI
                • MasterCraft Prostar
                #22
                Ethanol is just another government "solution"... instead of simply drilling for our own oil, we're providing subsidies to turn our food/feed supplies into fuel. In WI, we can purchase both gasoline and E10, therefore I have first hand experience how subpar ethanol is. The average gas milage is reduced by 30%, which more than offsets the reduced price at the pump. I don't run ethanol in my boat, but I can tell almost instantly the performance difference ethanol makes if I use it my car. For every government action, there is an equal but opposite reaction. Sorry for the vent, but it is 3:15am here in beautiful WI! Drill baby drill!!
                '08 196LE (previous)
                '07 196LE (previous)
                2 - '06 196SE's (previous)
                • nordeast
                  • Aug 2010
                  • 9
                  • Champlin, MN
                  • 1984 Ski Nautique 2001
                  #23
                  1984 SN confused about fuel
                  I've read through this entire thread and I'm still confused. I just bought a 1984 SN and right on the the gas cap it says not to use fuel that contains alcohol. Doesn't ethanol have alcohol in it? I have this boat up in the woods of WI and trailering to a gas station is a pain but trying to find regular gas may be real tough.
                  Do I have to run regular leaded gas in this or can I run ethanol in this boat without doing damage to it? If so should I be running a fuel stabilizer like seafoam in it (for moisture) or using a lead additive?
                  This is our first inboard and I just want to do right by my boat and try not to make any expensive boneheaded mistakes.
                  Thanks for the help,
                  Tony
                  • AirTool
                    • 4049
                    • Katy, Texas
                    #24
                    Originally posted by nordeast View Post
                    I've read through this entire thread ...........
                    For your inboard,
                    Ethanol is ethyl alcohol.
                    E10 is okay in general. You won't have much choice otherwise.
                    Avoid E15 and never E85.
                    Avoid Seafoam for any use and it is expecially not a fuel stabilizer. It is modern snake oil for your engine and the only benefit is to the dealer and mfg that swiped 10 bucks out of your pocket.
                    • swc5150
                      • 2240
                      • Eau Claire, WI
                      #25
                      AT is correct. Most people don't have a choice, and have to run E10. We're fortunate in WI to still be able to buy 100% gasoline, although it's only sold as 93 octane - which is not necessary in these motors.
                      • j2nh
                        • Dec 2003
                        • 628
                        • Spread Eagle Wisconsin
                        #26
                        I'll echo what Scott said, in WI we can still get 100% gasoline, unfortunately it is 93 octane. I run it because it is pure gas, not because of the higher octane.
                        Government created this mess and like everything else once the government starts something there is no way to stop it.
                        2018 200 Team H6
                        2009 196 Team ZR 409
                        2005 196 Limited ZR 375
                        2003 196 Limited Excalibur
                        1999 196 Masters Edition
                        1987 ProStar 190
                        • shag
                          • 2217
                          I actually just ran a tank of regular non-ethanol gas in my Sierra (found it at a station near Mt Dora Florida, which is the only station in central Florida to carry it) and I got 17-18 mpg, as opposed to 13-14 mpg. Same type of driving, actually more start and stop driving on the Non-ethanol tank. What a crock of crap ethanol is. There was a commercial I saw recently that Ethanol has created X number of jobs...... Yeah, fixing small engines that have gunked up carbs from this crap.
                          Sorry, just my .02
                          • AirTool
                            • 4049
                            • Katy, Texas
                            #28
                            Sorry, just my .02
                            And fixing 2 stroke outboards with melted pistons.
                            Ethanol is for drinking and that's all. (Except in or around my boat - y'all know my rule on that.)
                            I saw a Food Network show the other night and there was a guy bragging on his clear plastic water bottles made from corn. I wanted to call and ask him if he knew that those green tractors in the corn fields burned diesel.
                            • engkid_486
                              • Aug 2010
                              • 40
                              • Southern Maryland
                              • 2004 Super Air Nautique Team Edition
                              #29
                              I am a Newbie as well to the Nautique family. Last week I recently purchased a 04 SANTE with the ZR6 6.0L powerplant. My question is also that the manual says "Most PCM Fuel Injected engines are calibrated to operate on 87 octane fuel and maximum performance is obtained when using this fuel. Some applications may require a higher octane fuel. These particular applications will be noted." Is it reccommeded for me to run 87 octane fuel in my Nautique?
                              • engkid_486
                                • Aug 2010
                                • 40
                                • Southern Maryland
                                #30
                                Ok.... So I did a search and answered my own question. All PCM (GM) after 2002 use 87 Octane Gasoline (Regular).
