oil pressure is staying around 50..... and goes up to 60 when i increase rpm and comes back down to the 50 range....................it idles at around 600 rpm .................what happens to oil pressure if bearing is spun?
Originally posted by g33b0 View Postoil pressure is staying around 50..... and goes up to 60 when i increase rpm and comes back down to the 50 range....................it idles at around 600 rpm .................what happens to oil pressure if bearing is spun?
i dont know if this is relevant.....but not all of the plugs shocked me when i pulled em.......only a couple of them...........when i pulled the second wire on the driver side, starting from front going to back of boat....to me the knocking seemed to change and quiet but wasnt completely gone
Re: gt40 knocking
Oil pressure can be good with a spun bearing as long as you haven't run the engine down the road like what usually happens in cars. In a car the rods will get so hot they fuse to the crank or they spray metal in the crankcase, or in my case (racing) let go of the piston and damage the top end too. Clogs up the oil system.
- Jun 2008
- 2080
- Flowery Branch GA Lake Lanier
- 2008 210 SANTE 67 Correct Craft Mustang
The thing that confuses me is how can you spin a bearing simply by de winterizing . Its my understanding this boat hasn't seen water since last year. It was fine then I still think its a lifter I cant wait to see what the mechanic says.
Knocking
Another way to check to see what is going on inside your motor is to cut open the oil filter. An engine that is having problems with bearings is going to have small chips of metal inside the filter on the "paper". To cut open the filter use a sharp knife or filter cutter, don't use a hack saw or any other object that is going to put metal chips inside the filter. Start cutting around the outside near the screw on area and gasket. Once you have cut all around it you can seperate the paper filter material from the steel frame. Open up the paper and look for any copper colored flecks. If you see any you could have problems inside your engine with bad bearings. Good luck.
My bet is a rod bearing or wrist pin...I garon-teee.
I've forgotton what kind of wrist pin bushings 350 chevy uses (if at all). But it sound to me like if they use a bushing...that it is GONE. I've heard the exact same sound in other engines. Rod bearing failures at the crank are usually a soft growl from down low. I do not think it is in the valve train because the engine is running so smoooooth. (At least it sounds like it is....is the engine missing or idling rough?)
The other thing you could do is to carefully grab an oil sample and send it in for analysis. That might tell you if there is either babbit or bronze in the oil. Babbit would be a bearing. Bronze would likely be the wrist pin busing (if that is what chevy uses...need to check if there is a bushing or steel to steel fit. Steel in the oil might indicate a rounded off cam lobe.
A d m i n i s t r a t o r
- Mar 2002
- 16517
- Lake Norman
- Mooresville, NC
He's got a GT-40, not a Chevy.I own and operate Silver Cove Marine, which is an inboard boat restoration, service, and sales facility located in Mooresville, North Carolina. We specializes in Nautiques and Correct Crafts, and also provide general service for Nautiques fifteen years old and older.
Originally posted by NautiqueJeff View PostHe's got a GT-40, not a Chevy.
I'll see if I can find a guts breakdown to see how the piston/wrist pin/ rod are attached.
I'll still bet it is something associated with a rod until he tells me the engine is rough/missing.
from just listening to it............i dont think the engine is missing.......it sounds like a strong solid grumble at idle...........when i removed the manifold on the driver side....the gasket appeared to be worn.......first chance i get, i think i will get new riser and exhaust gaskets, even tho yous guys dont think that is my problem........i hope yall are all wrong...lol............going to mechanic first thing in the morning............my nautique guy that i get my advice from hasnt seen my engine personally, but vouches that in his 15 years of gt40 nautique experience that he has never heard of a gt40 with valve, pushrod trouble,,and thinks i have an exhaust leak.........my prob is..........i know how i run and maintenance my new boat, which is immaculate to the T..... ..but i dont know how the last owners maintenanced this glorious beast, therefore i might have a spun bearing..........this is a sad sad day that i have to throw in the towel and take it to someone i dont trust and pay him for advice that yall are giving me....." i have done and will continue to do any and all(if possible} service on my boat.......i love to learn ,........and there aint nothing to it but to do it.........
Originally posted by g33b0 View Postexplain more on the piston pin please
Find an eploded view and you will see.
Absent of an exhaust leak. You now have two experts (2gofaster and airtool) voting on wrist pins.
If you can get a small 1/4" bar or rod in through each spark plug hole, I can tell you a way to check for extreme slop. I've diagnosed this before on other engines.
You might be able to locate which cylinder using a mechanic's stethoscope. I often use the radio antenna off my truck as a stethoscope.
