size of thru hulls for factory ballast tank vents in 2000 Air
  • wcherashore
    • Sep 2009
    • 190
    • San Diego, CA
    what are the size of the factory ballast tank vents in a 2000 Air.
    I am looking to put in an integrated system and am wondering if they are the appropriate size. If they are 0.5" will I have to blow them out to 0.75"?
    The two rear sacks will vent using the stock vents and will be each fed by a reversible pump. Similarly, a bag in the center locker will vent using the air/priming thru hull also used for the stock tanks.
