Center bag install 03 limited SAN
  • caverlyc
    • May 2009
    • 37
    • Minnesota
    • 2008 MasterCraft x2 (current) 2003 Super Air 210 Limited (sold) 1995 Ski Nautique (sold)
    I am installing a center bag in my 03 SAN limited. It never had a center tank so I am adding a bag. I have a ballast puppy for a pump (reversable). I want to use my belly fill button on my key pad, but i can only find the empty wires. Where in the F@$# are my fill wires? I dont want that ugly togle switch. Can anyone point me in the direction of the fill wires (a diagram says there is two sets of wires for the factory two pumps) and how is everyone wiring the jabsco ballast puppy pumps so you can use the keypad buttons? All my holes are drilled and ready for plumbing. Just want to get this completed so I can get out on the water!! Thanks!!!
    Curt
  • caverlyc
    • May 2009
    • 37
    • Minnesota
    Finally got jabsco to run off keypad, 03 SAN
    Curt
    I finished my cetnter bag install on my 03 SAN. To run my Jabsco pump off of my key pad with the belly fill/empty button I had to run two relays to reverse polarity on the ballast puppy. With 4 wires out of the switch and 2 on the pump I had to run 2 double throw double pull relays to get it or run both directions. Real pain but worth it!! My belly fill wires were stuck under the gas tank; fun to find!! Will post pics of install and wiring so you dont have to use the ugly switch.
    • cama
      • Apr 2010
      • 20
      • 2007 Air Nautique 216 Team
      Curt
      Did you end up getting this working? I am trying to do the same with an 2007 Air 216 team. Found the wires for the rear tanks but cant find anything for belly
