What prop should I use? I just purchase 07 SAN 220 with smaller engine and it had a 1235 prop on it. I noticed that each blade was slightly bent close to the end about the same, almost like it was mad that way. Anyway, I don't no the top speed of boat since speedometer and PP were way off but it seemed to be about 36mph. Should it be more than that? I normally wakeboard but every once in a while I'll barefoot or teach someone to barefoot, so 36mph won't cut it. I purchased a stock prop from dealer and just took it out with GPS and it does 43mph but it created more problems. It has no low end power...It messes up PP even more than the normall cornering 5mph variations. And when tubing, it really sucked because there was no power to sling the rider. What prop should I use? Should I try and get the 1235 prop fixed and use it? If so, what will top speed be? Also, which is going to be more fuel efficient since I mostly wakeboard?
