Jabso Ballast Puppy question
  • jackkloepfer
    • Nov 2008
    • 58
    I'm noticing a pretty wide gap in pricing on these, anywhere from ~$190 to $280. Are there different types? What is the difference with the "yellow" impeller?
    Thanks.
  • WakeSlayer
    • Sep 2005
    • 2069
    • Silver Creek, MN
    • 1968 Mustang
    You have to make sure you are comparing the same correct pump. 18220-1127 is the one you want. Also, make sure it includes the rocker switch. I believe they are sold with and without.
    The yellow impellers were the 2nd generation. The black ones burned out fairly easy. That said, I have never replaced mine. I do have a pair of yellows in the boat just in case. There is also now a green impeller. Not sure what the difference is there.
    the WakeSlayer
    1968 Correct Craft Mustang
    • Dave210TE
      • Apr 2010
      • 45
      • 2006 super air 210 TE
      I think the green one is a new replacement for the yellow one. I think it is made from a new material so lasts even longer. I also think i need a new ballast pump because the pump for the starboard ballast tank as stopped making the deep whining nose that the other pumps make when filling the tanks and that tank does not fill at all any more.
      • Latonkaboarder
        • Jul 2007
        • 372
        • Mercer, Pennsylvania
        • 81 Ski Nautique when growing up 2007 SANTE 210 2008 SANTE 210
        Dave, change your impeller. I have had to replaced two and both appeared to be in good shape. They don't break the fins off like your water pump impeller. I believe the hub on them starts spinning around.
        Current: 08 Super Air 210 Team
        Previous: 07 Super Air 210 Team
        Previous: 02 MC Pro Star 197
        • WakeSlayer
          • Sep 2005
          • 2069
          • Silver Creek, MN
          • 1968 Mustang
          Correct, the hub does spin out.
          the WakeSlayer
          • Chexi
            • Apr 2025
            • 2119
            • Austin
            • 2000 SAN
            Before the new impellers, I believe that many people extended the lives of their impellers by running the impeller in the opposite diretion for a second or two after filling or emptying the tanks (i.e., flip the switch for just a bit to reverse the direction of the fins after your fill or empty your tanks).
            Now
            2000 SAN
            Previously
            1999 Air Nautique
            1996 Tige Pre-2000
