1980 Ski nautique vibration???
  • T-Mez
    • May 2010
    • 1
    • 1980 Ski Nautique
    I just got a 1980 ski nautique and it runs good just has a vibration through the drive line...It seems to be straight and the prop does not look to dinged up, there is a little play in the part that is under the boat that holds the drive shaft, if the bushing gets wore will the boat vibrate on the gas an when you turn??
    Thanks T-MEZ
  • WakeSlayer
    • Sep 2005
    • 2069
    • Silver Creek, MN
    • 1968 Mustang
    It could well be your propeller, but you should align your motor, trans, and shaft. A boat that old will more than need it.
    Read this thread, by transmission expert Eric Lavine, Fantastic Finish Marine.
    http://www.correctcraftfan.com/forum...lignment+shaft
    the WakeSlayer
    1968 Correct Craft Mustang
