I have a 2002 Super Air Team Edition with wedge tanks and the belly tank. With stock ballast filled the boat has a porpoise to it at around 22mph and on. Ive heard of this with the Python motor however mine has the Excalibur 330. I filled a 150 pound fat sack all the way in the very front and the porpoising went away. My first question is this common?
My second question has to do with adding more weight. I am thinking about adding the fly high wedge sacs in the back. Wakemakers says they are 260 pounds each. So 520 pounds added to the rear. Would 350 pounds be sufficient up front to keep things ballanced? I figured its just a little more than doubling the stock system in the same locations (a little further forward hoping it will help with the porpoising) I dont really want to do the integrated bow sac due to having to cut out the cooler. I have been contemplating a bow triangle and barely filling it or having a custom sac made. Any thoughts?
