Heater (under)performance on 2008 236
  • louismblais
    • Oct 2008
    • 57
    • 2008 236 TE 2002 SANTE (previous) 2008 Seadoo speedster (first)
    Hey!
    I got a brand new 2008 236 (not a typo!) and I find the performance of the heater to leave something to be desired. It is not as efficient as my old 2002 SAN TE's heater or the one in my friend's Moomba, the air it pushes simply isn't as hot. Does anyone know a quick fix for that?
    My boat only has 7 hours, I'm not sure but I think I might have heard or read somewhere that it takes some time for a heater to reach it's peak performance. Anyone can confirm or infirm that?
  • ClemsonDave
    • Oct 2004
    • 659
    • Glen Allen, VA
    • Ski Nautique 200
    What is the engine temp? Is it not hot just at idle, or all the time?
    Promo Team member
    1999 196
    2010 200 Team 2010 200 Team
    2011 200 Team 2011 200 Team
    2012 200 Team - 2012 200 Team
    2013 200 Team - 2013 200 Team
    2014 200 Team - 2014 200 Team
    2015 200 Team - on the way
    • xrichard
      • Aug 2008
      • 667
      • El Dorado Hills
      • 2023 G23
      I've never heard that it takes time (engine hours) to reach peak performance. It's the same as a car heater: hot water is pumped through a little radiator and a fan blows air over it...which is directed through outlet vents.
      Mine heater was awful. I checked the lines and found one kinked--fixed that and all is good. Based on other posts I've read, I think a kinked / pinched hose is more common that you'd expect.
      I also installed the y-fitting Heatercraft sells to increase heat output at idle. It seems to work well at idle, but I think it's at the expense of heat at higher RPM.
      Previous boats:
      2015 G23
      2008 SAN 210
      2002 XStar
      1995 Sport Nautique
