Perfect pass issues
  • G
    • Aug 2006
    • 173
    • Mebane NC / Hyco Lake
    Perfect pass issues
    Some one please answer, probably a dumb question. I have a 2003 SAN with perfect pass on it. When I got the boat in 2006 it worked fine. Then one day it quit registering speed but it was on. All I did for the winter was take the cables off my batteries, and when I reconnected them today the PP will not even power up. Before I start taring into things, does this sound like the display on the dash has been going bad and finally bit the dust or should I start tracing wires. I don't use it much so I'm a little reluctant to spend a ton of money and time on it. Just curious what some of you guys have seen...... Thanks...
    MikeG.
  • eseybold
    • Apr 2008
    • 60
    Perfect pass requires a good solid connection with a good ground. Make sure that the your battery connections are good and remove the dash board cover and look to make sure that the perfect pass wires are secure. I had the same issue with my 2000 nautique and was simply a matter of a loose ground wire off PP.
    • G
      • Aug 2006
      • 173
      I started messing with my Perfect Pass again. I found the loose power cable. But I still can't get it to register any speed. I checked all the connections and all looked good. I checked and have 12volts at the module under the dash. The servo motor spins back and forth when you hit the igition switch. What is anyone's oppinon on what I might have going on. I don't have a manual for it so I have no way of reading anything about it and what the buttons do.... Thanks. MikeG.
      • NautiDave07
        • Mar 2008
        • 333
        • Louisville KY
        • 00 SAN210 07 236 TE
        The paddle wheels do wear out. if you trailer a lot you may want to consider taping over it so it doesn't spin while driving down the road. If you are getting no speed readout I would guess bad paddle wheel.
        00 SAN 210 (previous boat)
        07 236 te sold
        • G
          • Aug 2006
          • 173
          Yeah I do trailer it every weekend....I did notice before it quit registering, It would show speed then stop and start again, and stop so that makes sense. I will check into getting one. Thanks for the info.
          • ers906
            • Feb 2010
            • 921
            • Phoenix AZ
            Call perfect pass, their customer service is great
            Eric, Phoenix AZ
            G23 550 hp (finally here)
            2002 Super Air
            • Shooter
              • Apr 2025
              • 264
              • Orange County California
              • 2003 SANTE 210
              I had the same issue and contacted PP. They told me to reset the system. For me reset is holding on/off & menu when you turn it on. It works fine now. I dont know why it did this, but it didnt cost me anything to repair so I am happy.
              • DLafont
                • May 2009
                • 340
                • Gatineau Qc
                PPass customer service is awesome!
                I second that! I phoned them up a couple days ago, spoke to the head honcho (Gerry), he e-mailed me info on how to attack my issue.
                Previous: 1990 Ski Nautique
