Thermostat for best heater performance
  • jimmylee1000
    • May 2010
    • 20
    • 1993 Ski Nautique
    I just installed a heater in my 1993 Ski Nautique with the Ford 351 PCM engine. It blows warm air, but not REAL warm. I have the 143F thermostat, and am planning a change to the 160F thermostat:
    http://www.skidim.com/prodinfo.asp?number=RP026002
    Think it'll help? Anyone ever use the 170F thremostat: http://www.skidim.com/prodinfo.asp?number=RP026001
    Just wondering how to get the most toasty heat. I already installed the "Y" venturi pipe at the raw water pump inlet. My wife needs some more heat. Yuk yuk yuk.
  • pdxCC
    • Aug 2009
    • 143
    • Portland, Oregon
    • Current -> 01' Air Nautique Previous - 93' Ski Nautique
    If you check the threads carefully I belive the best place to pull the heater source is off the intake manifold. If I remember your pics you took it off the block which is where I am planning to pull my source from.
    I did have the 163 thermostat in my 93 for a day or two last season but I swapped back to the 143 just to be safe. From the conversations on here I think you are fine with either.
    ____________________________________________
    Current Boat --> 01' Air Nautique (April 12' to current!)
    Previous Boat - 93\' Ski Nautique Closed Bow ( Sept' 09 to March 12')
    • jimmylee1000
      • May 2010
      • 20
      • 1993 Ski Nautique
      I believe the 163F thermostat is preferred for engine performance these days. Has anyone ever used the 170F thermostat?
      • ClemsonDave
        • Oct 2004
        • 659
        • Glen Allen, VA
        • Ski Nautique 200
        I'd check with the dealer, but I don't see where 10* would make a difference. Engines are not very efficient when they are too cold. My truck motor has a 190ish thermostat. Pretty sure my corvette does too.
        Promo Team member
        1999 196
        2010 200 Team 2010 200 Team
        2011 200 Team 2011 200 Team
        2012 200 Team - 2012 200 Team
        2013 200 Team - 2013 200 Team
        2014 200 Team - 2014 200 Team
        2015 200 Team - on the way
        • WakeSlayer
          • Sep 2005
          • 2069
          • Silver Creek, MN
          • 1968 Mustang
          The general rule of thumb is carbed boat = 143*, EFI = 160*. Pull the hot water feed off your intake, and the return to the circulating pump.
          the WakeSlayer
          1968 Correct Craft Mustang
