Diagnostic Port Location
  • slob02
    • Sep 2003
    • 333
    2004 Excalibur 330 hp 5.7.........I have the tool to reset my KNOCK SENSOR code. Can someone tell me where the diagnostic port is located? I figure under the red motor covor, but I don't see any empty ports.
    Thanks!!
    2008 Super Air 210 Team
    2004 AIR 206 Team
    1997 Ski Nautique 196
    1993 Ski Nautique SNOB
  • slob02
    • Sep 2003
    • 333
    Found this old post from DanielC that answered my question!!!
    ............There is a connector under the plastic engine cover, that normally is attached to the Faria gateway box, that you can pull the codes from.
    This connector is called an "Assembly Line Communications Link" or an "Assembly Line Diagnostic Link", the connector is also called by its acronym "ALCL" or "ALDL".
    This is a 12 pin connector, two rows of six in a rectangle shape. Two of the corners are cut off, on one side of the connector, and there is a key tab on the other side of the connector in the middle. This connector has small letters, "A" through "M" identifying the connections. Look on top of the engine, to the left side of the centerline of the engine, forward of the fuel pump and computer relays. My directions are for a "direct drive" boat. Forward is the pulley end of the engine. If the engine is in a V-drive boat, the connector will still be on the left side of the engine, but on the Starboard side of the boat.
    I remember the replacement coil wire being red. I could be wrong on that.
    2004 AIR 206 Team
