Are factory ball valves epoxied to the through hulls and barbs?
  • TRDon
    • Oct 2007
    • 722
    • MN
    I cant seem to get my barb out of the ball valve threads. I want to screw my ballast pumps to the through hull because one doesnt seem to want to prime 50% of the time when I drop the boat in and I have to suck start it. It is connected to a hose and in the factory locations but one will prime all the time and the port one will not so I figued I can kill this problem by screwing it directly in but I cant get the barb out.
    Any ideas?
  • steve-o
    • Jul 2009
    • 231
    Mine wasn't, but I had to use big pipe wrenches to get them going. They had used joint compound on a couple of fittings.
    • TRDon
      • Oct 2007
      • 722
      • MN
      I really cant take the through hulls off unless I get the ball valve off, I guess I need to try harder. I didnt really think of the pipe wrench idea, I will try to use that. That is, if I can get them in there, which will be difficult at best.
      • steve-o
        • Jul 2009
        • 231
        Oh yeah, its a tight fit. Don't expect more than an inch of turning before you have to reposition it.
        • intrlaz
          • Aug 2009
          • 230
          You should not be removing factory ball valves unless they need to be replaced. Thats an easy way to sink the boat in the even of a component failure.
          Also, I removed mine (to replace them) with a large crescent wrench. You may need a breaker bar for some more leverage. They are extremely tight.
