I need a little help with the starter
  • moondog188
    • May 2010
    • 2
    I have an 1989 SN. I bought it about 2 weeks ago, took it out today and when starting the motor it cranks fine but the starter continues run after the boat cranks. I tried hitting the ingition button to kill the power but the starter still continued to run. I also tried turning off the key switch and it still kept turning the motor over. The starter looks like it is new and so does the soenoid. Finnaly I stopped it by turning the key switch on and off several times. Any thoughts will be greatly appreciated.
  • j2nh
    • Dec 2003
    • 628
    • Spread Eagle Wisconsin
    Contact cleaner in the ignition switch?
    2018 200 Team H6
    2009 196 Team ZR 409
    2005 196 Limited ZR 375
    2003 196 Limited Excalibur
    1999 196 Masters Edition
    1987 ProStar 190
    • AirTool
      • 4049
      • Katy, Texas
      I probably should know...but can you tell me what kind of engine it has?
      • Nautiquehunter
        • Jun 2008
        • 2080
        Its most likely a 351w engine. Your problem is either the Ign switch or the starter relay. If the relay has two small terminals make sure the I terminal goes to the Ign switch not to the distributor. If it happens again disconnect the wire from the Ign switch going to the starter relay if it stops the Ign switch is probubly bad.
        • moondog188
          • May 2010
          • 2
          thnaks for the input. it is a ford 351 ford. i will check the switch and the relay
