This saturday wakeboarded and surfed all day... Bout time to head in and all of a sudden I have a loss of power in the engine and check engine light comes on.. Sends me into limp mode all the way to the dock?? Do I just need to take it in and get diagnosed or is it somethin simple..its an 05 Nautique 226
mine is doing basically the same thing. there a few things that can be checked from what i have gathered. manually check oil pressure and fuel pressure. if the oil pressure is correct it could be a bad sender/switch or both. it could also be a low pressure fuel pump. how many hours do you have? i have about 480 on an 05' ex330. it wants to flash the low oil pressure code, but usually only gets to low oil and then stops flashing, but remains in limp mode w/ check engine light on. i unhooked all my batteries and the code disappeared and doesn't go into limp anymore, but does not have good throttle response. if you can check those things mentioned above, and if not just take it to your dealer.
