Help....I am in limp mode!!
  • Mega226
    • Mar 2009
    • 7
    This saturday wakeboarded and surfed all day... Bout time to head in and all of a sudden I have a loss of power in the engine and check engine light comes on.. Sends me into limp mode all the way to the dock?? Do I just need to take it in and get diagnosed or is it somethin simple..its an 05 Nautique 226
  • hourglass
    • Mar 2010
    • 248
    • lower bama
    • 2005 SANTE
    mine is doing basically the same thing. there a few things that can be checked from what i have gathered. manually check oil pressure and fuel pressure. if the oil pressure is correct it could be a bad sender/switch or both. it could also be a low pressure fuel pump. how many hours do you have? i have about 480 on an 05' ex330. it wants to flash the low oil pressure code, but usually only gets to low oil and then stops flashing, but remains in limp mode w/ check engine light on. i unhooked all my batteries and the code disappeared and doesn't go into limp anymore, but does not have good throttle response. if you can check those things mentioned above, and if not just take it to your dealer.
    • Mega226
      • Mar 2009
      • 7
      Thx a million man!!!
      • Latonkaboarder
        • Jul 2007
        • 372
        • Mercer, Pennsylvania
        • 81 Ski Nautique when growing up 2007 SANTE 210 2008 SANTE 210
        Could it possibly be the impellar? I think it will go into limp mode if your impellar is bad and the engine gets hot. Did you notice if the engine temp was hot?
        Current: 08 Super Air 210 Team
        Previous: 02 MC Pro Star 197
