Running Hot after Impeller Change
  • Proud2BeCC
    • Mar 2004
    • 201
    • Warsaw, IN
    • 2002 Sport Nautique
    I have a 2002 Sport and changed the impeller prior to taking it out for the first time this season. I normally run a garden hose with water into the intake to verify it functioned OK. This time however, I ran out of time and I took it straight to the lake for the weekend. Put the boat in and started great as normal. Then while going out to the main body of water, my boat got HOT (i.e. 180-220 deg). Went into limp mode. We pulled it out and let it cool down...then pulled the impeller to verify everything looked good. After putting the impeller and water pump back in, I ran water from a garden hose in the system this time. We put the boat in the water the next day and the temp did not go over 160 degrees. For the most part, it ran between 145-155 degrees. Could I have had a vapor lock in the cooling system? Just curious on your thoughts.
    Thanks,
    _____________________________________________
    Proud2BeCC
    2002 Sport Nautique
    (NDT) New Dimension Tower
    TowerBinimi Binimi Top
    Clarion CMD5
  • Chopper
    • Jul 2004
    • 92
    • Brisbane Australia
    • 1989 Ski Nautique SN2001 1991 Ski Nautique 196 1998 Ski Nautique 196 2003 Super Air Nautique
    You may have inadvertantly reinstalled the impeller housing upside down, and corrected it when you took it back off to check it.
    Very easy error on the ford block.
    • Lvnspeed
      • Aug 2008
      • 393
      • Smith Lake AL
      possible there is a loose hose sucking air?
      2003 226 LE
      • Proud2BeCC
        • Mar 2004
        • 201
        • Warsaw, IN
        Sorry....forgot to mention that I have the excalibur engine. Installed the RP061017 Impeller Kit....Genuine PCM parts.
        Proud2BeCC
        2002 Sport Nautique
        Clarion CMD5
